Hi
Just to inform people that in some cases and with certain devices the function I2C_Send7bitAddress in STM32 FwLib is not working correctly and does not trigger the event I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED so the run of the program gets stuck into an infinite while loop.
I would recommend to use the code below to replace the I2C_Send7bitAddress if you encounter issues with I2C on STM32 :
// send address //I2C_Send7bitAddress(I2Cx, address, direction); // not working if(direction == I2C_Direction_Transmitter) I2C_SendData(I2Cx, (address << 1) | 0); else if(direction == I2C_Direction_Receiver) I2C_SendData(I2Cx, (address << 1) | 1); // check if slave acknowledged his address within timeout if(direction == I2C_Direction_Transmitter) while(!I2C_CheckEvent(I2Cx, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED)); else if(direction == I2C_Direction_Receiver) while(!I2C_CheckEvent(I2Cx, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
Here is a related thread talking about this issue: http://www.keil.com/forum/18440/
Romain
