Hi, I am working with Tiva C series and Keil IDE. I want to generate PWM signals using PWM modulator present in Tiva C series. I had compiled the code successfully but when I simulated getting errors like this
*** error 65: access violation at 0x400FE058 : no 'write' permission *** error 65: access violation at 0x400FE640 : no 'write' permission *** error 65: access violation at 0x400FE06C : no 'read' permission *** error 65: access violation at 0x400FE06C : no 'read' permission *** error 65: access violation at 0x400FE06C : no 'read' permission
continuously getting errors like this and I can't able to run the code in the simulation mode and also not able to view these signals in the logic analyzer. I am attaching my project code along with this. Need Solution
#include <stdint.h> #include <stdbool.h> #include "inc/hw_gpio.h" #include "inc/hw_types.h" #include "inc/hw_memmap.h" #include "driverlib/sysctl.h" #include "driverlib/pin_map.h" #include "driverlib/gpio.h" #include "driverlib/pwm.h" #define GPIO_PB6_M0PWM0 0x00011804 #define GPIO_PB7_M0PWM1 0x00011C04 #define GPIO_PB4_M0PWM2 0x00011004 #define GPIO_PB5_M0PWM3 0x00011404 #define GPIO_PE4_M0PWM4 0x00041004 #define GPIO_PE5_M0PWM5 0x00041404 #define GPIO_PF1_M1PWM5 0x00050405 #define GPIO_PF2_M1PWM6 0x00050805 #define GPIO_PF3_M1PWM7 0x00050C05 #define SYSCTL_RCGC2_R (*((volatile unsigned long *)0x400FE108)) #define SYSCTL_RCGC2_GPIOF 0x00000020 // port B Clock Gating Control int main(void) { unsigned long ulPeriod; volatile unsigned long delay; SYSCTL_RCGC2_R |= SYSCTL_RCGC2_GPIOF; // activate port B delay = SYSCTL_RCGC2_R; // allow time to finish activating //Set the clock SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN | SYSCTL_XTAL_16MHZ); //Configure PWM Clock to match system SysCtlPWMClockSet(SYSCTL_PWMDIV_1); // Enable the peripherals used by this program. SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF); SysCtlPeripheralEnable(SYSCTL_PERIPH_PWM1); //The Tiva Launchpad has two modules (0 and 1). Module 1 covers the LED pins ulPeriod = SysCtlClockGet() / 200; //PWM frequency 200HZ //Configure PF1,PF2,PF3 Pins as PWM GPIOPinConfigure(GPIO_PF1_M1PWM5); GPIOPinConfigure(GPIO_PF2_M1PWM6); GPIOPinConfigure(GPIO_PF3_M1PWM7); GPIOPinTypePWM(GPIO_PORTF_BASE, GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_3); //Configure PWM Options //PWM_GEN_2 Covers M1PWM4 and M1PWM5 //PWM_GEN_3 Covers M1PWM6 and M1PWM7 See page 207 4/11/13 DriverLib doc PWMGenConfigure(PWM1_BASE, PWM_GEN_2, PWM_GEN_MODE_UP_DOWN | PWM_GEN_MODE_NO_SYNC); PWMGenConfigure(PWM1_BASE, PWM_GEN_3, PWM_GEN_MODE_UP_DOWN | PWM_GEN_MODE_NO_SYNC); //Set the Period (expressed in clock ticks) PWMGenPeriodSet(PWM1_BASE, PWM_GEN_2, ulPeriod); PWMGenPeriodSet(PWM1_BASE, PWM_GEN_3, ulPeriod); //Set PWM duty-50% (Period /2) PWMPulseWidthSet(PWM1_BASE, PWM_OUT_5,ulPeriod/2); PWMPulseWidthSet(PWM1_BASE, PWM_OUT_6,ulPeriod/2); PWMPulseWidthSet(PWM1_BASE, PWM_OUT_7,ulPeriod/2); // Enable the PWM generator PWMGenEnable(PWM1_BASE, PWM_GEN_2); PWMGenEnable(PWM1_BASE, PWM_GEN_3); // Turn on the Output pins PWMOutputState(PWM1_BASE, PWM_OUT_5_BIT |PWM_OUT_6_BIT|PWM_OUT_7_BIT, true); //Do nothing while(1) { } }
