Hello Everybody,
I sreeni, working on Tiva C series MCU(32K RAM) based application and want to allocate the space in heap of more than 0x1000 bytes of memory.
It works fine when I allocate 0x1000 bytes of memory in startup.s file, but in my application I need to allocate a memory of 10K but I am getting the following error when I try to allocate more than 0x1000 bytes of heap space in startup.c file.
linking... Trial_Link_CSU.axf: Error: L6406E: No space in execution regions with .ANY selector matching startup.o(STACK). Trial_Link_CSU.axf: Error: L6406E: No space in execution regions with .ANY selector matching picojpeg.o(.data). Trial_Link_CSU.axf: Error: L6406E: No space in execution regions with .ANY selector matching variables.o(.bss). Trial_Link_CSU.axf: Error: L6406E: No space in execution regions with .ANY selector matching mmc-ek-lm4f232h5qd.o(.data). Trial_Link_CSU.axf: Error: L6406E: No space in execution regions with .ANY selector matching variables.o(.data). Trial_Link_CSU.axf: Error: L6407E: Sections of aggregate size 0x16c bytes could not fit into .ANY selector(s). Target not created
Any help is appreciated.
Thanks, sreeni
Hi All,
One more thing didn't mentioned, when I allocate the heap size of 0x1000k in startup.s file then the size of memory used is as follows
Program Size: Code=12918 RO-data=98 RW-data=124 ZI-data=8436
thanks sreeni
So have you made sure your processor has enough RAM for both the global variables and stack and heap? Or if it has multiple RAM regions - have you made sure you allocations allows the linker to fit the global data requirements of the individual object files in a way that makes it fit into the available RAM regions?
