I have written a code to open/create a text file in keil4 IDE, but not able to creat it, here is my code,
#include "inc/tm4c123gh6pm.h" #include <stdint.h> #include <stdbool.h> #include <stdio.h>
FILE *f_Write = NULL; char buf[512];
int main(void) { // here i tried by giving different paths by inserting USB(U:,U0:), SD card (M), and also with default drive and flash drive.
f_Write = fopen("F:\\file4.txt","w");
if (!f_Write) return 1;
fclose(f_Write); return 0; }
I have tried building the code with CCS compiler also, here file is created, but when i try to write some content it is not being written. If i read different file by opening it in read mode(manually by writing some content) both fgets and fgetc functions pointing to NULL and EOF at single reading.
I am not getting any errors but file operations are not being done in ccs, in keil file is not created, can anyone please help me out where i am going wrong.
Thanks & Regards, Mamatha
This is embedded, you're hosting this file system how exactly? Where do you think the processor is going when you return from main()?
