Feature clasified as BUG
In C:
struct XYZ table[10];
table[index].ID = 2;
This code produce assembly which implements library ?C?LIMUL2
There is no option to put this code into any other segment,then CODE.
This is supposed to be called BUG with no workaround.
Creating own libray function but located in ECODE doesn't help.
The code expect ?C?function instead of ?PR?function which I provide
Deadlock
Robert
