SST89E516RD DTR reset problem
I am using a automatic reset feature by using a transistor switched reset via DTR for the MCU. All codes are programmed and working except any of those that deal with serial communication. As soon as I open hyper terminal and connect to my MCU board the DTR constantly holds 8051 to reset and system doesnt works. Here is the image link where I have used my MCU and connections. www.quora.com/.../What-pins-are-used-to-upload-a-program-to-a-8051-IC
  • Works well - listens to the mobile networks to auto-detect if it should generate 50Hz or 60Hz and to adjust the output voltage depending on where in the world you use it. The only disadvantage is that if you start the inverter when all cellular base stations are down (maybe after a massive power outage) then the inverter will refuse to power on since it can't auto-calibrate output voltage/frequency.
    Complete source code and schematics available in this LINK.
