I am working on mcb2300 board. I want to generate a pulse from it.I wrote a programme for this.but when I run this program in the board all values got changed.the same program works efficiently in simulation.but on it is not working properly.My program code is as
#include <LPC23xx.H> /* include for LPC23xx */ void PWMInit() { /* considering LPC2368 */ PINSEL3 |= (0x02<<8); /* reset PWM counter */ PWM1TCR = 0x02; /* setup match control to reset on MR0 */ PWM1MCR = 0x02; /*Reset on PWWMR0*/ /* select single edge for PWM1.1... and enable PWM1.2 o/p */ PWM1PCR = (1 << 10); /* setup PWM period */ PWM1MR0 = 12000000000/500; /* setup PWM duty cycle (50%) */ PWM1MR2 = PWM1MR0/2; /* start counter and enable PWM */ PWM1TCR = 0x81; /* enable LER */ PWM1LER = 0x04; } int main() { PWMInit(); while(1); } please help me....
