USB Enumeration Problem in W7
I have a Omapl138 board, I am trying to connect a USB to the same. M using windows 7 OS. while I am debugging USB firmware code I can see a the following sequence of Signal transfer.
1. a Reset signal
2. device descriptor request
3. set address request
again the same pattern repeating for 4 times.
can anybody help to find why its not come out of these sequence..?
I should get a device confg request next right..?
  • > I should get a device confg request next right..?
    Windows7 in this sequence.
    - Bus reset
    - Get_Descriptor(Device) - first 8 bytes
    - Set_Address
    - Get_Descriptor(Device) - full size
    - Get_Descriptor(String) - first 2 bytes
    - Get_Descriptor(String) - full size
    - Get_Descriptor(Config) - first 4 bytes
    - Get_Descriptor(Config) - full size
    Anyway, your firmware should not "expect" the next request.
    Your firmware should respond to any request properly, corresponding to the device stage.
    it may fail at the status stage of set_address
    OR
    Are you making your own stack?
    or playing on an existing stack like Linux gadget?
    Tsuneo
  • Yes I am using a existing stack. And I am getting the sequence like
    > reset
    > reset
    > Set_Address
    > reset .... and again repeating the same pattern.
    I have a doubt for the first Get_Descriptor(Device) request my stack sending 18bytes of data. will it cause any problem..??
    Thank you.
  • After first 8 bytes of Device Descriptor Windows host will terminate further reception of IN packets by sending OUT zero length packet, and after this anyways bus will be reset.
