I have some trouble for building an application on M0 core of LPC43xx serie
My application worked fine .. Then I updated all software pack
Now, each time I try to make an application for M0 core of a LPC43xx using CMSIS RTOS component, Keil automatically adds file "RTX_CM4.lib" instead of "RTX_CM0.lib" needed for M0 core (as Keil did before).
How can I solve that ? (all examples from software pack don't build anymore neither)
Thank you.
I have the following erros during linking part :
.\Objects\M0.axf: Error: L6367E: rt_cmsis.o(.rev16_text) attributes are not compatible with the provided cpu and fpu attributes . Object rt_cmsis.o contains Build Attributes that are incompatible with the CPU attributes. Tag_CPU_arch = ARM v7E-M (=13) Tag_CPU_arch_profile = The microcontroller profile 'M' (e.g. for Cortex M3) (=77) Tag_THUMB_ISA_use = Thumb2 instructions were permitted (implies Thumb instructions permitted) (=2)
Problem solved with Keil 5.13 =)
