I am using LPC2388 on my boards. I try to connect 4 devices to a computer via TCP. So i have 5 MAC address. But sometimes system is locked. If i power off one of the device so there is no problem.
What is the solution?
Isn't goal number one to figure out what the problem is?
Like if you have fixed IP or if you use DHCP? And in that case what the DHCP server thinks about the situation.
And "system is locked"? What system? All networking dead between every device and PC? Between PC and something else?
