Compile Error ( STM32 )
Hi All,
I'm the beginner on using STM32F101C4,try to start on I2C, so i download STM32F10x_AN2598_FW_V3.1.0, it's work on compiling with default MCU( STM32F103 ), but when i change the MCU to STM32F101C4, the following errors will appear soon, would you please tell me what's the problems? Thanks!
compiling main.c...
..\..\..\Libraries\CMSIS\CM3\DeviceSupport\ST\STM32F10x\stm32f10x.h(317): error: #67: expected a "}" ADC1_2_IRQn = 18, /*!< ADC1 and ADC2 global Interrupt */
..\..\..\Libraries\CMSIS\CM3\DeviceSupport\ST\STM32F10x\stm32f10x.h(406): warning: #12-D: parsing restarts here after previous syntax error } IRQn_Type;
..\src\main.c(104): error: #20: identifier "I2C2_EV_IRQn" is undefined NVIC_SetPriority(I2C2_EV_IRQn, 0x00);
..\src\main.c(107): error: #20: identifier "I2C2_ER_IRQn" is undefined NVIC_SetPriority(I2C2_ER_IRQn, 0x01);
..\src\main.c: 1 warning, 3 errors
"..\src\main.c" - 3 Error(s), 1 Warning(s).
  • Have you made any effort yourself to find the problem?
    So have you opened the file stm32f10x.h and looked at line 317 to see why it might be expecting a "}" there...?
  • Make sure the include paths for your project are complete, and override the default libraries Keil may be using. These things don't mix-n-match well.
    Check the Preprocessor defines to ensure you have the correct settings for you specific chip, some of the Low Density and Value Line classes of processors have only a subset of peripherals compared to the Medium and High Density ones. The startup files, and interrupt vectors, may well be different too.
    If there are example or template projects for your board/chip try using those, and reviewing the options/settings they use.
  • And, again, be sure to use the corresponding Libraries direct from the ST Site - the ones included by Keil are unlikely to be compatible...
