Hello! I want to know how can i find out when someone pressed a key in Uart1.
/* /* Includes ------------------------------------------------------------------*/ #include "91x_lib.h" /* Private typedef -----------------------------------------------------------*/ /* Private define ------------------------------------------------------------*/ #define TxBufferSize (countof(TxBuffer) - 1) /* Private macro -------------------------------------------------------------*/ #define countof(a) (sizeof(a) / sizeof(*(a))) /* Private variables ---------------------------------------------------------*/ UART_InitTypeDef UART_InitStructure; u8 TxBuffer[] = "UART Example1: UART - Hyperterminal communication using hardware flow control\n\r"; u8 NbrOfDataToTransfer = TxBufferSize; u8 TxCounter = 0; /* Private function prototypes -----------------------------------------------*/ void SCU_Configuration(void); void GPIO_Configuration(void); /* Private functions ---------------------------------------------------------*/ /******************************************************************************* * Function Name : main * Description : Main program * Input : None * Output : None * Return : None *******************************************************************************/ int main() { #ifdef DEBUG debug(); #endif /* Configure the system clocks */ SCU_Configuration(); /* Configure the GPIO ports */ GPIO_Configuration(); /* UART0 configuration -----------------------------------------------------*/ /* UART0 configured as follow: - Word Length = 7 Bits - Two Stop Bit - No parity - BaudRate = 115200 baud - Hardware flow control enabled (RTS and CTS signals) - Receive and transmit enabled - Receive and transmit FIFOs are enabled - Transmit and Receive FIFOs levels have 8 bytes depth */ UART_InitStructure.UART_WordLength = UART_WordLength_7D; UART_InitStructure.UART_StopBits = UART_StopBits_2; UART_InitStructure.UART_Parity = UART_Parity_No ; UART_InitStructure.UART_BaudRate = 115200; UART_InitStructure.UART_HardwareFlowControl = UART_HardwareFlowControl_RTS_CTS; UART_InitStructure.UART_Mode = UART_Mode_Tx_Rx; UART_InitStructure.UART_FIFO = UART_FIFO_Disable; UART_DeInit(UART0); UART_Init(UART0, &UART_InitStructure); /*enable UART Rx Interrupt*/ UART_ITConfig(UART0, UART_IT_Receive , ENABLE); /*configure UART0 interrupt in VIC*/ VIC_DeInit(); VIC_InitDefaultVectors(); /* initialize VICs default vector registers*/ VIC_Config(UART0_ITLine, VIC_IRQ, 0); /* Enable the UART0 */ UART_Cmd(UART0, ENABLE); /* Communication hyperterminal-UART0 using the hardware flow control */ /* Send a buffer from UART to hyperterminal */ while(NbrOfDataToTransfer--) { UART_SendData(UART0, TxBuffer[TxCounter++]); while(UART_GetFlagStatus(UART0, UART_FLAG_TxFIFOFull) != RESET); } /*enable UART0 interrupt for data reception*/ VIC_ITCmd(UART0_ITLine,ENABLE); while (1); } /* * Function Name : SCU_Configuration * Description : Configures the Master clock @96MHz and the Main system * configuration and Clocks (FMI,PLL,RCLK,HCLK,PCLK ,MCLK ) * and enable clocks for peripherals. * Input : None * Output : None * Return : None *******************************************************************************/ void SCU_Configuration(void) { SCU_MCLKSourceConfig(SCU_MCLK_OSC); /* Default configuration */ /*wait state insertion :This function should be executed from SRAM when*/ /*booting from bank1 to avoid Read-While-Write from the Same Bank.*/ FMI_Config(FMI_READ_WAIT_STATE_2, FMI_WRITE_WAIT_STATE_0, FMI_PWD_ENABLE,\ FMI_LVD_ENABLE, FMI_FREQ_HIGH);/*Insert 2 Wait States for read*/ SCU_PLLFactorsConfig(192, 25, 2); /* PLL factors Configuration based on*/ /* a OSC/Crystal value = 25Mhz*/ SCU_PLLCmd(ENABLE); /* PLL Enable and wait for Locking*/ SCU_RCLKDivisorConfig(SCU_RCLK_Div1); /* RCLK @96Mhz */ SCU_HCLKDivisorConfig(SCU_HCLK_Div1); /* AHB @96Mhz */ SCU_FMICLKDivisorConfig(SCU_FMICLK_Div1);/* FMI @96Mhz */ SCU_PCLKDivisorConfig(SCU_PCLK_Div2); /* APB @48Mhz */ SCU_MCLKSourceConfig(SCU_MCLK_PLL); /* MCLK @96Mhz */ /* Enable UART0 Clock */ SCU_APBPeriphClockConfig(__UART0, ENABLE); /* Enable VIC clock */ SCU_AHBPeriphClockConfig(__VIC, ENABLE); /* Enable GPIO2 Clock */ SCU_APBPeriphClockConfig(__GPIO2, ENABLE); /* Enable GPIO3 Clock */ SCU_APBPeriphClockConfig(__GPIO3, ENABLE); /* Enable GPIO5 Clock */ SCU_APBPeriphClockConfig(__GPIO5, ENABLE); } void GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; /*Configure UART0_CTS P2.0*/ GPIO_DeInit(GPIO2); /*After DeInit function P2.0 = UART0_CTS (defaut configuration)*/ GPIO_DeInit(GPIO5); /*Gonfigure UART0_Rx pin GPIO5.1*/ GPIO_InitStructure.GPIO_Direction = GPIO_PinInput; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; GPIO_InitStructure.GPIO_IPInputConnected = GPIO_IPInputConnected_Enable; GPIO_InitStructure.GPIO_Alternate = GPIO_InputAlt1 ; GPIO_Init (GPIO5, &GPIO_InitStructure); GPIO_DeInit(GPIO3); /*Gonfigure UART0_Tx pin GPIO3.4*/ GPIO_InitStructure.GPIO_Direction = GPIO_PinOutput; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4; GPIO_InitStructure.GPIO_Type = GPIO_Type_PushPull ; GPIO_InitStructure.GPIO_Alternate = GPIO_OutputAlt3 ; GPIO_Init (GPIO3, &GPIO_InitStructure); /*Gonfigure UART0_RTS pin GPIO3.3*/ GPIO_InitStructure.GPIO_Direction = GPIO_PinOutput; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3; GPIO_InitStructure.GPIO_Type = GPIO_Type_PushPull ; GPIO_InitStructure.GPIO_Alternate = GPIO_OutputAlt3 ; GPIO_Init (GPIO3, &GPIO_InitStructure); }
What i want to do is to turn on a led when a key from keyboard is pressed. How can i do that? Thank you !
What keyboard?
What does a keyboard have to do with a UART?
The keyboard from an computer, Uart being used in simulator mode.
So have you studied the simulator Documentation?
Go to the uVision Manual
Find the Simulator section
See what it says about UART Communication...
Thank you, but there is something that i can't understand. How i know in my program that i am writing somenthing in the serial window Uart1? And how can i read that caracter? For example if i press 'a' where is it stored this caracter? Thank you for your patience.
The documentation tells you how to "connect" a simulator Serial Window to a simulated UART.
When you've done that, anything you type into the Serial Window will appear as received characters to the UART, and transmitted characters from the UART will appear in the window.
How i know in my program that i am writing somenthing in the serial window Uart1 in an ISR
No toolset so a generic question??? How did you think - that your processor is identical to all other processors in this world?
Then I understand how you have failed to read the chip documentation to locate the UART status register and the relevant flags.
Given the amount of code you have while not knowing the answer to your question, I have to assume you found these code lines but doesn't fully understand them.
Reading documentation really is important - copy code when your skill level allows you to understand (and write) the code.
You don't.
Your program knows nothing of the serial window. All it can see is the UART - or, rather, the registers associated with the UART.
So you need to study the documentation for the UART - to see what facilities exist to tell you when something's been received...
