Hi Everyone,
I've been facing difficulty in writing code in call back functions of i2c.
I mean I am totally blank.
Please help me.
I am trying to communicate in between LPC936.
I have programmed one as Master and the other as slave.
Thanks in Advance! Kaustubh
I2C transactions can be performed without callback functions.
So you'd better start with some really basic documents, and really basic examples - then work your way up...
one asimpe way to remember: An I²C slave can not 'send', it can only 'respond'
Thank you Everyone!
But still I have one doubt.
If data is transmitted by master and received by slave and slave responds to masters' call, where is I2DAT value actually transferred from and where is it received?
Thanks in advance!
The only 'response' a receiving slave has is ACK or NAK.
as said before you need to read up on the I²C protocol.
I might have been a bit fuzzy
The only 'response' a receiving slave has to a master transmit is ACK or NAK.
Thanks Eric for your help! But I am gonna need more of it.
I have configured one Micro-controller as slave with address 0x01(I2ADR=address<<1. Therefore I2ADR = 0x02).
Now Master (another Micro-controller) calls slave i2c_receive(0x01). But unfortunately Master enters status, slave address + read transmitted, NACK received.
Now I2DAT in master is 0x03 i.e 0000 001 for address and LSB = 1 for read.
Please help me!
Where possibly did I go wrong?
Kaustubh
I am sorry previously i hadn't mentioned Micro-controller used.
I am using P89LPC936.
And the problem i had discussed was seen on hardware.
Thanks!
as a matter of fact I do rccall correctly. I once used this as a base for something
Thanks Erik!
I got my output.
Thank you! :-)
