Has anyone encountered this problem and do you have a solution? I've included info on the IDE below and am using Keil runtime library V3.1. I'm trying to build a simple multicast application.
Thanks, Mike
IDE-Version: µVision V4.21.0.0 Copyright (C) 2011 ARM Ltd and ARM Germany GmbH. All rights reserved.
Tool Version Numbers: Toolchain: MDK-ARM Professional Version: 4.21 Middleware: RL-ARM Real-Time Library Version V4.12 Toolchain Path: BIN40\ C Compiler: Armcc.Exe V4.1.0.713 Assembler: Armasm.Exe V4.1.0.713 Linker/Locator: ArmLink.Exe V4.1.0.713 Librarian: ArmAr.Exe V4.1.0.713 Hex Converter: FromElf.Exe V4.1.0.713 CPU DLL: SARMCM3.DLL V4.21 Dialog DLL: DLM.DLL V1.22 Target DLL: BIN\UL2CM3.DLL V1.90 Dialog DLL: TLM.DLL V1.21
Figure out which of the two objects/sources you ACTUALLY need, or if you need to set up some pre-processor defines to include/exclude specific files, or pieces thereof.
I had the same issue. Enabling IGMP Group Management (IGMP_ENABLE set to 1 in net_config.c) will solve the problem. Thanks.
Thanks Joseph - I found the same thing.
