My Program code is following:
system.c
#include <reg51.h>
#include <Memory.set> #include <Delay.h>
void main(void) {
//unsigned char xdata uc_xdata_Buf[32768];
//uc_xdata_Buf[0]=1;
Delay_Ms_24M(1);
Memory.set
//--------------------------------------------------------------------------------------------- //Test //---------------------------------------------------------------------------------------------
unsigned char xdata uc_xdata_Buf[32768] _at_ 0x0010;
Error Message as following: Comm Group\Memory.set(5): error A9: SYNTAX ERROR Comm Group\Memory.set(5): error A3: ILLEGAL CHARACTER Comm Group\Memory.set(5): error A3: ILLEGAL CHARACTER Comm Group\Memory.set(6): warning A41: MISSING 'END' STATEMENT
Please give me suggestion. Thanx.
first: DO NOT retype code into the forum use cut-and-paste. There has been a lot of threads that ran forever because the error was different in the retype than in the code.
second: if you want help with errors, mark the lines in your source the errors refer to or only someone that has hours on hand could try (most likely w/o success) to help you.
Sorry. I posted the question in this forum first time. I hasnt known what happen in my program. So I paste two files content (System.c and Memory.set). If the post is not OK. Please tell me again. I will delete it. Thanx.
do not forget to mark the lines the error messages refer to
I define a array in the other file(Memory.set). But I use the array in system.c and I compile it. It show the errow message. Memory.set has something wrong. If I move the array definition to the system.c. It can pass. Everything is ok. My Program code is following:
#include <reg51.h> #include <Memory.set> #include <Delay.h>
void main(void) { //unsigned char xdata uc_xdata_Buf[32768];->If the array definition move to here.It will be Ok.
uc_xdata_Buf[0]=1;
unsigned char xdata uc_xdata_Buf[32768] _at_ 0x0010;------>Error
I found why error happen. I have two group. The Main group has system.c. The Comm group has memory.set. If I remove the memory.set from Comm group. The error disappear. Thanx.
