Serial to Ethernet conveter
Here my application is whatever data Received through serial(UART1) and Transmit via Ethernet
For this application we used LPC1768 micro controller and taken reference software code is EasyWeb.uvproj.
EasyWeb source code modified local port as TELNET, even though data transmit via Ethernet is very slow and every one second one data can able to transmit.
We need as soon as received data from serial, it should transmit very fast via Ethernet.
For this communication am using Hyper Terminal Windows
Please any one help me how to over come this problem.
Regards,
Ashok
  • Did you spend any time considering/investigating whether that was a suitable basis for your project? Did you consider any alternatives?
    What investigation have you done to determine where the bottleneck/delay lies?
  • Thanks for replay. I hope its suitable for my project, but am not able to find where delay will generate for every transmission data through Ethernet.
    Please suggest me referring code is whether suitable or not.
  • But what have you done to ensure that it's suitable.
    It's your project - so this is stuff that you need to do.
  • I am using easy Web example program on mcb1700 evaluation board. I want to modified it for continuous data transfer. this program transfer one frame and tcp socket is getting close.
    can anybody suggest me how to transfer continuous data without closing tcp scoket.
  • So you keep saying.
    But you still don't seem to have given any thought to whether that is good basis for your project.
  • No, am not implement any different TCP/IP stack. I following same function DoNetworkStuff();
    I made zero of RETRY_TIMEOUT, FIN_TIMEOUT & MAX_RETRYS in tcp.h file.
    Socket library also same as DoNetworkStuff();
    When i receive complete word like "hello" through serial, its able to transmit only one character 'h' only via ethernet. we want to achieve complete string transmit via ethernet
    please guide me which statement need to change in my code as per my application.
    int main(void)
    //InitOsc();              // Keil: No oscillator initialization necessary at this time.
    //InitPorts();                       // Keil: No port initialization necessary at this time.
      SysTick_Config(SystemCoreClock/100);               /* Generate interrupt every 10 ms */
      LPC_GPIO1->FIODIR   |= 1 << 28;                    /* P1.28 defined as Output (LED) */
      LPC_PINCON->PINSEL1 |=  (1<<18);                   /* P0.25 is AD0.2 */
      LPC_SC->PCONP       |=  (1<<12);                   /* Enable power to ADC block */
      LPC_ADC->ADCR        =  (1<< 2) |                  /* select AD0.2 pin */
                              (4<< 8) |                  /* ADC clock is 25MHz/5 */
                              (1<<21);                   /* enable ADC */
      SER_Init();
      TCPLowLevelInit();
      TELNETStatus = 0;
      TCPLocalPort = 23;//TCP_TELENET
      ui_uartcirbufend = 0;
      ui_uartcirbufstart = 0;
    while (1)                                      // repeat forever
        if (!( SocketStatus & SOCK_ACTIVE ))
                TCPPassiveOpen();
        if (( SocketStatus & SOCK_ACTIVE ))
              DoNetworkStuff();
        if((LPC_UART1->LSR & 0x01))
          uc_uartrxbuffer[ 0 ] = LPC_UART1->RBR;
          uc_uartrxbuffer[ 1 ] = '\0';
          Telnet_data_tx();
    void Telnet_data_tx( void )
     if (SocketStatus & SOCK_CONNECTED)             // check if somebody has connected to our TCP
          if (SocketStatus & SOCK_DATA_AVAILABLE)      // check if remote TCP sent data
               TCPReleaseRxBuffer();                      // and throw it away
        if (SocketStatus & SOCK_TX_BUF_RELEASED)     // check if buffer is free for TX
            TCPTxDataCount = 2;//MAX_TCP_TX_DATA_SIZE;   // bytes to xfer
            memcpy(TCP_TX_BUF, uc_uartrxbuffer, TCPTxDataCount);
            TCPTransmitTxBuffer();
    Note: ALL API are same as in DoNetworkStuff();
  • But you don't seem to care about buffering any untransmitted characters until the TCP part of the code is able to send out more data. And you also hardcode your transfer size. If there are 5 untransmitted characters - why would it then be a good idea to only send one character?
  • Any modification required in DoNetworkStuff() function for continuous transmitting data via Ethernet without any delay adding( for instant data appear )
  • Yes, similar application only, but i need help for implements on LPC1768.
    Is it required to add RTOS.
  • What help, exactly? None of it is specific to any particular processor.
    "Is it required to add RTOS"
    Did you study the App Note?
    Did you spend any time with google?
  • How to read / know the MAC ID for individual chip of LPC1768
  • How to store variable in flash memory by using lpc1768.
