UART1 lpc1768
How to config uart1 in lpc1768 for ppp conection with gprs modem.
serial port driver for lpc1768
  • Best way to be doing it is with some code
  • The UART neither knows nor cares that it is (or is not) being used for PPP - it just sends bytes, and receives them.
    So configuring a UART for PPP is no different to configuring it for any other purpose. Therefore you must just read the documentation for the UART, and do what it tells you.
    You can also look at any examples of using the UART - it doesn't matter, at the level of sending & receiving bytes, whether they specifically do PPP or not.
    Or, is your real question how to implement PPP...?
  • I need serial port driver for uart1 in lpc1768 and use lpc21xx driver but I have problem in uart1 interupt
    /*---------------------------------------------------------------------------- * RL-ARM - TCPnet *---------------------------------------------------------------------------- * Name: SERIAL.C * Purpose: Serial Port Driver for Philips LPC21xx * Rev.: V4.05 *---------------------------------------------------------------------------- * This code is part of the RealView Run-Time Library. * Copyright (c) 2004-2009 KEIL - An ARM Company. All rights reserved. *---------------------------------------------------------------------------*/
    #include <Net_Config.h>
    #include "lpc17xx.h" /* LPC21xx definitions */
    /* Local variables */
    struct buf_st { U8 in; U8 out; U8 buf [256];
    static struct buf_st rbuf;
    static struct buf_st tbuf;
    static BOOL tx_active;
    void handler_UART1 (void) __irq;
    /*---------------------------------------------------------------------------- * Serial Driver Functions *---------------------------------------------------------------------------- * Required functions for Serial driver module: * - void init_serial () * - int com_get_char () * - BOOL com_putchar (U8 c) * - BOOL com_tx_active () * - interrupt function(s) *---------------------------------------------------------------------------*/
    /*--------------------------- init_serial -----------------------------------*/
    void init_serial (void) { /* Initialize the serial interface */ rbuf.in = 0; rbuf.out = 0; tbuf.in = 0; tbuf.out = 0; tx_active = __FALSE;
    ///////////////////////////////////////////// LPC_SC->PCONP |= ((1 << 4) | (1 << 15)); /* enable power to UART1 & IOCON */
    LPC_PINCON->PINSEL4 |= (2 << 0); /* Pin P2.0 used as TXD1 */ LPC_PINCON->PINSEL4 |= (2 << 2); /* Pin P2.1 used as RXD1 */ /////////////////////////////////////////////// /* Enable RxD1 and TxD1 pins. */
    // PINSEL0 &= ~0x000F0000;
    // PINSEL0 |= 0x00050000; /* 8-bits, no parity, 1 stop bit */ LPC_UART1->LCR = 0x83; /* 19200 Baud Rate @ 15MHz VPB Clock */ LPC_UART1->DLL = 49; LPC_UART1->DLM = 0; LPC_UART1->LCR = 0x03; /* Enable RDA and THRE interrupts. */ LPC_UART1->IER = 0x03; /* Enable UART1 interrupts. */ NVIC_EnableIRQ (UART1_IRQn);
    // VICVectAddr14 = (U32)handler_UART1;
    // VICVectCntl14 = 0x27;
    // VICIntEnable = (1 << 7);
    /*--------------------------- com_putchar -----------------------------------*/
    BOOL com_putchar (U8 c) { struct buf_st *p = &tbuf;
    /* Write a byte to serial interface */ if ((U8)(p->in + 1) == p->out) { /* Serial transmit buffer is full. */ return (__FALSE); }
    // VICIntEnClr = (1 << 7); if (tx_active == __FALSE) { /* Send directly to UART. */ LPC_UART1->THR = (U8)c; tx_active = __TRUE; } else { /* Add data to transmit buffer. */ p->buf [p->in++] = c; }
    // VICIntEnable = (1 << 7); return (__TRUE);
    /*--------------------------- com_getchar -----------------------------------*/
    int com_getchar (void) { /* Read a byte from serial interface */ struct buf_st *p = &rbuf;
    if (p->in == p->out) { /* Serial receive buffer is empty. */ return (-1); } return (p->buf[p->out++]);
    /*--------------------------- com_tx_active ---------------------------------*/
    BOOL com_tx_active (void) { /* Return status Transmitter active/not active. */ /* When transmit buffer is empty, 'tx_active' is FALSE. */ return (tx_active);
    /*--------------------------- handler_UART1 ---------------------------------*/
    void handler_UART1 (void) __irq { /* Serial Rx and Tx interrupt handler. */ struct buf_st *p; U8 rbr;
    if ((LPC_UART1->IIR & 0x0E) == 0x04) { /* Serial Receive Interrupt. */ p = &rbuf; /* Read a character to clear RDA Interrupt. */ rbr = LPC_UART1->RBR; if ((p->in + 1) != p->out) { p->buf [p->in++] = (U8)rbr; } } if (LPC_UART1->LSR & 0x20) { /* Serial Transmit Interrupt. */ p = &tbuf; if (p->in != p->out) { LPC_UART1->THR = p->buf [p->out++]; } else { tx_active = __FALSE; } } /* Acknowledge Interrupt. */
    // VICVectAddr = 0;
    /*---------------------------------------------------------------------------- * end of file *---------------------------------------------------------------------------*/
