I'm working on Cortex M0 and I have an issue with the linker ( linker v5.03 from KEIL 4.72a ).
I want the linker to place data in a given memory area except in a small sub-area.
So I used the EMPTY attribute like this:
LR_FLASH 0x00800000 0x8000 { EMPTY 0x00806F00 EMPTY 0x530 { }
OTHER { *.o (*) } }
But the linker places data from OTHER region in the EMPTY region.
I think I misunderstood the usage of EMPTY attribute.
Thanks for your help
One easy way to create a hole in the flash is to instead specify that you have two separate flash regions available.
You can map a char array in there - the linker will have no choice but to comply. Place your array in a separate module or a section (see linker user manual).
That's what I wanted to avoid... but am currently doing !
Thank you for this suggestion but I don't want any data ( even dummy ) to be mapped in the area.
If you plan to write data in there in the future, you better allocate an entire sector - not 0x530 bytes. If you fill your array with binary 0xF (1111111) in the binary, you will be able to write immediately without first erasing - the very first time. Watch out while updating your firmware in the field - allow the bootloader to skip this region so you don't erase intermittent data. I would recommend against leaving holes - I no longer use the Keil toolchain but I encountered a lot of "pleasantries" by the linker in the past under certain conditions.
