toggling port pins through an element in a structure
Here is what I am trying to do:
sbit PORT_1_0 = P1^0;
void main ()
{ PORT_1_0 = 1; while(1) { PORT_1_0 =~ PORT_1_0; }
Now this is as simple as it gets.
The question is, is it possible to do the same thing using an element of a struct?
Something like:
struct abc
{ unsigned char bit : 1;
struct bit bit_array[24];
bit_array[0].bit = P1^0; //Assign the port pin to be toggled
//and then the toggling here.
Basically, how to assign a port pin to the bit in a struct? I am doing this because based on the address of a frame, I need to decide which pin is to be set.
I hope you get the question.
