Hi all,
I'm trying to get a simple ADC working on the stm32f4 discovery board. At the moment I simply want to obtain an input value (ConvertedValue) as a variable rather than saving to memory in DMA. I'm struggling with the pins - some of them give me a little functionality and others none at all. I cant get any port to work properly. PIN0 will work to an extent - it will read a changing value, but it is also outputting a voltage of 2 volts which I've not told it to - and so any readings it gets are somewhat distorted.
I'd really appreciate anyone taking a look at the code im using (its mostly taken from various sources around the web - not really my own)
#include "stm32f4xx_adc.h" #include "stm32f4xx_gpio.h" #include "stm32f4xx_rcc.h" #include "led.h" #include "stm32f4_discovery.h" #include "stm32f4xx_tim.h" #include "stm32f4xx_dac.h" int ConvertedValue = 0; //Converted value read from ADC1 void adc_configure(){ ADC_InitTypeDef ADC_init_structure; //Structure for adc confguration GPIO_InitTypeDef GPIO_initStructre; //Structure for analog input pin //Clock configuration RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);//The ADC1 is connected the APB2 peripheral bus thus we will use its clock source RCC_AHB1PeriphClockCmd(RCC_AHB1ENR_GPIOCEN,ENABLE);//Clock for the ADC port!! Do not forget about this one ;) //Analog pin configuration GPIO_StructInit(&GPIO_initStructre); GPIO_initStructre.GPIO_Pin = GPIO_Pin_0;//The channel 10 is connected to PC0 GPIO_initStructre.GPIO_Mode = GPIO_Mode_AN; //The PC0 pin is configured in analog mode GPIO_initStructre.GPIO_PuPd = GPIO_PuPd_NOPULL; //We don't need any pull up or pull down GPIO_Init(GPIOE,&GPIO_initStructre);//Affecting the port with the initialization structure configuration //ADC structure configuration ADC_DeInit(); ADC_init_structure.ADC_DataAlign = ADC_DataAlign_Right;//data converted will be shifted to right ADC_init_structure.ADC_Resolution = ADC_Resolution_12b;//Input voltage is converted into a 12bit number giving a maximum value of 4096 ADC_init_structure.ADC_ContinuousConvMode = ENABLE; //the conversion is continuous, the input data is converted more than once ADC_init_structure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1;// conversion is synchronous with TIM1 and CC1 (actually I'm not sure about this one :/) ADC_init_structure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;//no trigger for conversion ADC_init_structure.ADC_NbrOfConversion = 1;//I think this one is clear :p ADC_init_structure.ADC_ScanConvMode = DISABLE;//The scan is configured in one channel ADC_Init(ADC1,&ADC_init_structure);//Initialize ADC with the previous configuration //Enable ADC conversion ADC_Cmd(ADC1,ENABLE); //Select the channel to be read from ADC_RegularChannelConfig(ADC1,ADC_Channel_10,1,ADC_SampleTime_144Cycles); } int adc_convert(){ ADC_SoftwareStartConv(ADC1);//Start the conversion while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC));//Processing the conversion return ADC_GetConversionValue(ADC1); //Return the converted data } //void dac_configure(){ /* Preconfiguration before using DAC----------------------------------------*/ // GPIO_InitTypeDef GPIO_InitStructure; /* DMA1 clock and GPIOA clock enable (to be used with DAC) */ // RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1 | RCC_AHB1Periph_GPIOA, ENABLE); /* DAC Periph clock enable */ // RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE); /* DAC channel 1 & 2 (DAC_OUT1 = PA.4)(DAC_OUT2 = PA.5) configuration */ // GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5; // GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN; // GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; // GPIO_Init(GPIOA, &GPIO_InitStructure); /* TIM6 Configuration ------------------------------------------------------*/ // TIM6_Config(); PUT BACK!!!!!!!!!!!!!!!!!!!! /* Configures User Button */ // STM_EVAL_PBInit(BUTTON_USER, BUTTON_MODE_EXTI); //} int main(void){ adc_configure();//Start configuration //dac_configure(); while(1) {//loop while the board is working ConvertedValue = adc_convert();//Read the ADC converted value //DAC_Ch1_WaveConfig(); } } //void DAC_Ch1_WaveConfig(void) //{ //DAC_DeInit(); // DAC_InitTypeDef DAC_InitStructure; // DAC_InitStructure.DAC_Trigger = DAC_Trigger_None; // DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None; //DAC_InitStructure.DAC_LFSRUnmask_TriangleAmplitude = DAC_LFSRUnmask_Bits11_0; //DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Enable; // DAC_Init(DAC_Channel_1, &DAC_InitStructure); // DAC_Cmd(DAC_Channel_1, ENABLE); //DAC_SetChannel1Data(DAC_Align_12b_R, ConvertedValue); //}
