I am generating optimsed code using simulink coder for LMS filter using stm32f4VG407 discovery board,KEIL MDK-ARM, but upon single conversion of signal through ADC , it is stopping at hardfault handler. fault report: MM_FAULT_STAT:0x00 BUS_FAULT_STAT:0x04 i.e. IMPRECISERR IS HIGH USG_FAULT_STAT:0x000 HARD_FAULT_STAT:0x4000000 i.e.FORCED IS HIGH DBG_FAULT_STAT:0x00000001 i.e. HALTED IS HIGH
I am using Matlab 2013b & MDK_ARM 4.74 please help me how to get rid of this.
Debugging? If you get into a hard fault, you have to assume that you have too small stack, or the code for some reason do an out-of-bounds access or makes use of an invalid data pointer or maybe sees an invalid instruction because of an invalid code pointer.
Debugging of available state in the trap handler can give you some ideas where it fails. Verifying stack size can also help. Standard, traditional code review can also be a good way to catch what possible error situations that might hit you.
Good chance your ADC is not powered up !
since it is MATLAB generated code ,it should work on its own without much editing from user side....so I have no idea how to do it...... Also I am not able to increase stack size by editing startup_stm32f4xx.s since it is locked Also code coverage tool option is not active....
also since BFARVALID of Bus Fault status register is high so there is valid bus fault again IMPRECISERR is high i.e.a data bus error has occurred ,
from "USING CORTEX-M3 AND CORTEX-M4 FAULT EXCEPTIONS" document: FORCED: Indicates a forced Hard Fault, generated by escalation of a fault with configurable priority that cannot be handled, either because of priority or because it is disabled
FORCED of Hard Fault status register is high means :When this bit is set, the Hard Fault handler must read the other fault status registers to find the cause of the fault.
So may be it is pointing to bus fault.
please help me regarding this
ADC is powered up since , it is converting for once & then stopping at HardFault_Handler
So move a copy of startup_stm32f4xx.s into your project directory, and remove the read-only attribute.
Review the code and processor registers at the fault location.
what has worked for me is to replace the hard fault handler with
GLOBAL char q = 1
while (q);
set a breakpoint on the while, when it stops, set q to zero step, step and you are where the hardfalt was detected
ADC is powered up since.... Does your adc have IRQ handler? Chances are that the adc interrupt may be enabled but doesnt have dedicated IRQ handler.
I am still struck in hard fault exception
after running 36 times(i.e 36 adc conversions & hence 36 outputs at dac) the program is getting into hard fault exception from within this for loop:
/* Update weights for the next input sample */ j_0 = 0; for (j = (int32_T)*startIdx; j < wLen; j++) { prodMuErrX = accWtU * xBuf[j]; prodMuErrX += mul_s32_s32_s32_sr30(leakFac, wBuf[j_0]); wBuf[j_0] = prodMuErrX; j_0++; }
I even checked changing stack size but the number of conversions (i.e 36 ) was independent of change in stack size.
Can somebody please help me regarding this?
Hello Satyajit Sahoo,
maybe Application Note 209 (http://www.keil.com/appnotes/docs/apnt_209.asp) helps you examining the HardFault.
Best Regards, Martin
