Hi Guys
I'm busy with a massive project where I need write software for a control system for an automotive vehicle. Here's what I am using:
1. I'm using an STM32F4 for the micro 2. I am writing the Application (Control app) in Matlab Simulink. I then generate Cortex M4 optimised code from Matlab which I simply Include in my Keil uVision Project. (Works like a charm) 3. I manually write software for the driver layer and to interface to the Hardware abstraction Layer.
I would like to maintain separation between my Simulink Generated Code and my 'firmware' hand written code. Essentially, I want to be able to change the firmware without affecting my control application.
I would like to use a configuration file to map the variables that Matlab Simulink generates with my Hardware Registers (for GPIO, for instance). I would like to do this via a configuration file (e.g. via an xml file).
Has anyone ever done something like this and is it even possible. I'm looking for an elegant solution that does not consume a lot of RAM.
Thanks so much!
PS: Is it possible to declare variables in your code based on variables names that are stored in say an .xml or .txt file.
So if in the .txt file I have "Pressure_Sensor = 0", is it possible, perhaps using a Macro Definition, to declare a variable in the code: Pressure_Sensor = 0;
I'd imagine you could automate the process with a pre-build AWK script, or some interface layer between the two source trees.
Yeah that'd be easy, except I need to do the variable mapping post compilation.
I want to be to change a set of variables( say K1 and K2) that are mapped to say GPIO PortC pin 1 & 2 to Pin 3 or 4 using only a configuration file that I load during run time...
I'm probably not explaining myself too well... :-(
The code is for an automotive application and it really helps not to recompile code in the field because vehicle wiring changed slightly.
Then make sure you split the two halves completely, and have the core functionality act as a loader of your application portion. I'd have a linker generate me an ELF executable image, and load that into RAM against the pin translation table in a configuration file.
