I am trying to write a program for an electrical device which needs calibration. The program must calibrate the device and store calibration values. This process is performed in RAM, but I need MCU to retain these information even when the power goes out. Is it the case in IAP? I mean if I copy calibration values from RAM to Flash memory using IAP, will I fulfill my requirement of not loosing them when the micro-controller is turned off?
Thanks in advance for your help
Yes, the whole point of Flash is that it is non-volatile; ie, its content is preserved when there's no power.
Things to consider:
Flash needs to be erased before writing/updating. The size and placement of flash blocks/sectors within you devices memory map. The minimum erase size, strategies to reduce wear (erase cycles). The erase and write speed with respect to w atchd ogs or real time behaviour. Shrinking your IROM size to accommodate a writable area outside the space the linker is using.
Thanks guys for answering, Now I know this is the right choice, however I have some coding problems now. I run into a hard fault when try to simulate the following code in keil-uv4.7 simulator. IAP does not run.
#include <LPC17xx.h> #include "ClockConfig.h" #define true 1 #define false 0 #define IAP_LOCATION 0x1FFF1FF1 unsigned int command[5]; unsigned int output[5]; typedef void (*IAP)(unsigned int [],unsigned int[]); #define iap_entry ((IAP) IAP_LOCATION) unsigned char x = 40; void IAP_WriteAndRead(unsigned char *variable); void Disconnect_PLL(void); int main() { SetCPUClock(); IAP_WriteAndRead(&x); while(true); } void Disconnect_PLL() { LPC_SC->PLL0CON = 0x01; LPC_SC->PLL0FEED = 0xAA; LPC_SC->PLL0FEED = 0x55; LPC_SC->PLL0CON = 0; LPC_SC->PLL0FEED = 0xAA; LPC_SC->PLL0FEED = 0x55; } void IAP_WriteAndRead(unsigned char *variable) { Disconnect_PLL(); command[0] = 50; command[1] = 0; // strat sector 0 command[2] = 0; // only sextor 0 is being written iap_entry(command, output); if (output[0]!=0) SetCPUClock(); else { command[0] = 51; command[1] = 0x100; command[2] = (unsigned int)x; command[3] = 512; command[4] = 12000; iap_entry(command, output); } SetCPUClock(); }
Keils simulator simulates a lot of hardware.
But that doesn't mean it simulates flash memory - and that it contains a copy of NXP:s proprietary boot loader.
