Error system clock tampering detected licence checkout will fail
Dear,
My KeilUV5 is licensed version but whenever i build code i got error message like
" system clock tampering detected license checkout will fail".
Please help me to solve this problem.
  • Don't you think that Keil Support explicitly exists for helping customers with this kind of problems?
    How much do you think other end users on a end-user forum can do about your licensing issues?
  • Was not expecting such a reply, but after buying a license (Which reached me after 2 months) when I install the compiler & get the license from net, the first thing your compiler flashes is clock tampering!!!!! vow.
    On forum there are no concrete answers, once again vow.
    In that case if KEIL has charged for the compiler then there has to be a straight support.
    If people are getting offended with a question, then please note that customer has paid & even after the compiler reached 2 months late is still unable to use the same.
    Sachin Shintre
    Sr. Manager R&D
    Transasia.
  • There are only 2 posts on discussion which are with "System Clock Tamper"
    One is ours & second is this
    http://www.keil.com/forum/58975/
    Where there is no conclusion & answers
    What you expect a customer should do??
    Sachin Shintre
    Sr. Manager R&D
    Transasia Biomedicals
  • What you expect a customer should do??
    As was previously suggested. Send a message to Keil support. It's about as easy as posting a message on this user forum and you'd be far more likely to get a solution.
    Bare Easterpoint
    Programmer (with a basic understanding of requesting information from the most appropriate source)
  • You did not expect such a reply, and wonder what a customer should do?
    Step one before using a forum would be to figure out the terms of use of the forum. That would have told you:
    "This forum is not monitored by Keil technical support personnel. Do not expect to receive technical support via this forum."
    So as an expecting customer, you would then instantly have expected that there must be a better path for getting support from Keil staff. And then noticed that both the top and bottom of every page contains menu choices/links mentioning "Support", "Contact" or similar.
    So - when something unexpected happens, it's a good idea to reevaluate your expectations. They might be wrong.
