Hi.
I have an axf image that once loaded (with load xyz.axf incremental) causes uVision.exe to crash (with a heap corruption unhandled exception in ntdll).
Same context works as expected loading a first axf image (a bootloader) and then loading incrementally aforementioned xyz.axf, so it shouldn't be due to ST-LINK+USBDriver components.
Is there any log that I could take a look at in order to better get what's going on?
Thanks!
...just to be more clear: in second case (loading bootloader.axf first and xyz.axf then) I get same bad behavior, i.e. uVision crashes!
Ciao Lorenzo,
can you please contact support regarding this issue ( http://www.keil.com/support/request.asp?P=&V=&S= )?
Kind regards,
Christopher
