Following code is used to generate delays on a cortex M0.
// for Cortex-M0 (subs for Cortex-M3) void y_delay_3x_cycles(uint32_t cycles) __attribute__((naked, used)); void y_delay_3x_cycles(uint32_t cycles __attribute__((unused))) { __asm( " sub r0, #1\n" " bne y_delay_3x_cycles\n" " bx lr" ); } #define CYCLES_PER_SECOND 12000000 void y_delay_us(uint32_t us) { y_delay_3x_cycles((us * CYCLES_PER_SECOND) / 3000000); } void y_delay_ms(uint32_t ms) { while (ms--) { y_delay_3x_cycles(CYCLES_PER_SECOND / 3000); } }
But when I compile with Keil, I get the following errors: ..\src\mp_micro.c(75): warning: #1207-D: unknown attribute "naked" void mp_micro_delay_3x_cycles(uint32_t cycles) __attribute__((naked, used)); ..\src\mp_micro.c(79): warning: #1267-D: Implicit physical register R0 should be defined as a variable " sub r0, #1\n" ..\src\mp_micro.c(79): error: #2829: Cannot perform desired action on condition flags " sub r0, #1\n" ..\src\mp_micro.c: 2 warnings, 1 error ___________________________________ I tried using a variable for the warning:
void mp_micro_delay_3x_cycles(uint32_t cycles __attribute__((unused))) { int regVariable; __asm( " sub regVariable, #1\n" " bne mp_micro_delay_3x_cycles\n" " bx lr" ); }
But still I get error #2829: Cannot perform desired action on condition flags
Why does the compiler ignore "naked":
..\src\y.c(75): warning: #1207-D: unknown attribute "naked"
What does the compiler manual say about the "naked" attribute?
I know the manual contains "used" but where did you find any documentation for "naked"? www.keil.com/.../armccref_babcighe.htm
Because it's not the GNU/GCC compiler? And it's not supported in Keil ARM compilers?
