Hi all,
I have a problem, every time I use my C8051F120-TB board and use peripheral -> port -> port 6 and try to turn the 4th bit into high logic (1), it always turn into low logic (0) no matter what project I'm using. This problem only happens to port 6. On the other hand, when I use simulator, everything is just fine. Anyone have ever had same problem? What should I do? Thanks
Adi
problem only happens to port 6. only thst bit? what do you have connected to that pin for SILabs chips you may be better off here: http://community.silabs.com/
I didn't connect anything to the port. I used the USB debug adapter and used the peripheral simulator to modify the port. Is there a certain setting before I debug the program?
AGAIN only thst bit?
Yes, only that bit
