adc sampling
HI sir, could you kindly explain me how to calculate the sampling frequency of adc in STM32F103ZET6 ?
I am not getting from any site this calculation. thanks
  • Guess you'd need to look at the ADCCLK, and the cycles programmed for sample time on each of channels being. If you wanted to quantify it, then toggle a GPIO on EOC and check with a scope.
    Normally if you want to hit a specific rate you'd use a timer, or other trigger, to start the conversion at the desired period.
