Find attached code which i am using for receiving single CAN message on LM3S8962 Stellaris Evaluation board.
(1)While debugging i am getting "error 59: Invalid Absolute module" error
Please help me in solving the error.
(2)Also i would like to know about below two lines. Whenevr i am compiling it shows me undefined error for GPIO_PA0_U0RX & GPIO_PA1_U0TX
GPIOPinConfigure(GPIO_PA0_U0RX); GPIOPinConfigure(GPIO_PA1_U0TX);
I tried it by including pin_map.h also but it makes no difference in error. I gone through the pin_map.h , there is no definition of above two parameter for lm3s8962. For other Board the definitions available.
Hence i kept them as comment kine in a code & then compiled sucessfully. What is the problem with it ?
