lpc23xx, capacitor on reset pin
Hi
I am having start up problems with lpc23xx devices. i.e sometimes the CPU does not start my code when power is connected
I activated brown out by changing PCON register and the situation got better
when I reduce the pull up resistor or the capacitor I have on the reset pin, the situation gets better
Finally I removed the capacitor and the was only a 39k pull up resistor on reset pin and the problem was solved. The core was starting normal operation each time I connected power
My question is that will this cause a problem if I don't use a capacitor on reset pin?
What other solution do you suggest to solve this problem?
  • An external supervisor IC would do a better job as the reset signal source, I think.
  • Thanks
    I looked at my supply voltage by oscilloscope and there was 500mV AC on my 3.3V Although I had 10 x100nF capacitors on the chip
    I added an electrolytic capacitor and now my circuit starts working even when I have 100nF capacitor on reset pin
    Just there is one more problem. I have a switch that connects reset pin to GND. When I apply a low to the reset pin, the chip stops and doesn't restart when I remove the low level on the reset pin
    Maybe the chip is entering ISP mode. but I have a 10K pull up resistor on P2.10. what else should I do?
    This is interesting that when jtag connector is connected to the board, the reset switch works fine and the CPU restarts normally after reset
  • R-C based reset circuits are a notoriously poor design choice, they will fail if the supply rise time is too slow, or if the reset glitches or the supply browns out.
    The use of a power-on-reset chip (Microchip has a couple, MCP120?), is strongly recommended to get a predictable and consistent reset pulse.
    and always fail on power down.
    power down problems are, almost, invariably reported as power up problems.
