Hi I'm working with keil And I'm going to use a GPIO interrupt. And the pin PIO0_1 I wrote this program
#include <LPC13xx.h>
void PIOINT0_IRQHandler(void) { LPC_GPIO2->DATA=0xaaa; LPC_GPIO0->IC = (1<<1); }
int main(void){
LPC_GPIO0->DIR = 0x000; LPC_GPIO2->DIR = 0xfff;
LPC_GPIO0->IS = 0x0; LPC_GPIO0->IBE = 0x2; LPC_GPIO0->IEV = 0x0; LPC_GPIO0->IE = 0x2;
NVIC_SetPriority(EINT0_IRQn,0); NVIC_EnableIRQ(EINT0_IRQn);
while(1){ LPC_GPIO2->DATA=0xf0f; LPC_GPIO2->DATA=0x0f0; }
But it does not work in keil simulator. Anyone knows the problem? Thanks.
Thanks. startup_LPC13xx.s:
; External Interrupts DCD I2C_IRQHandler ; 16+40: I2C DCD TIMER16_0_IRQHandler ; 16+41: 16-bit Counter-Timer 0 DCD TIMER16_1_IRQHandler ; 16+42: 16-bit Counter-Timer 1 DCD TIMER32_0_IRQHandler ; 16+43: 32-bit Counter-Timer 0 DCD TIMER32_1_IRQHandler ; 16+44: 32-bit Counter-Timer 1 DCD SSP0_IRQHandler ; 16+45: SSP0 DCD UART_IRQHandler ; 16+46: UART DCD USB_IRQHandler ; 16+47: USB IRQ DCD USB_FIQHandler ; 16+48: USB FIQ DCD ADC_IRQHandler ; 16+49: A/D Converter DCD WDT_IRQHandler ; 16+50: Watchdog Timer DCD BOD_IRQHandler ; 16+51: Brown Out Detect DCD FMC_IRQHandler ; 16+52: IP2111 Flash Memory Controller DCD PIOINT3_IRQHandler ; 16+53: PIO INT3 DCD PIOINT2_IRQHandler ; 16+54: PIO INT2 DCD PIOINT1_IRQHandler ; 16+55: PIO INT1 DCD PIOINT0_IRQHandler ; 16+56: PIO INT0 DCD SSP1_IRQHandler ; 16+57: SSP1
LPC13xx.h:
I2C_IRQn = 40, /*!< I2C Interrupt */ TIMER_16_0_IRQn = 41, /*!< 16-bit Timer0 Interrupt */ TIMER_16_1_IRQn = 42, /*!< 16-bit Timer1 Interrupt */ TIMER_32_0_IRQn = 43, /*!< 32-bit Timer0 Interrupt */ TIMER_32_1_IRQn = 44, /*!< 32-bit Timer1 Interrupt */ SSP0_IRQn = 45, /*!< SSP Interrupt */ UART_IRQn = 46, /*!< UART Interrupt */ USB_IRQn = 47, /*!< USB Regular Interrupt */ USB_FIQn = 48, /*!< USB Fast Interrupt */ ADC_IRQn = 49, /*!< A/D Converter Interrupt */ WDT_IRQn = 50, /*!< Watchdog timer Interrupt */ BOD_IRQn = 51, /*!< Brown Out Detect(BOD) Interrupt */ EINT3_IRQn = 53, /*!< External Interrupt 3 Interrupt */ EINT2_IRQn = 54, /*!< External Interrupt 2 Interrupt */ EINT1_IRQn = 55, /*!< External Interrupt 1 Interrupt */ EINT0_IRQn = 56, /*!< External Interrupt 0 Interrupt */ SSP1_IRQn = 57, /*!< SSP1 Interrupt */ } IRQn_Type;
gpio.h:
#define PORT0 0 #define PORT1 1 #define PORT2 2 #define PORT3 3 void PIOINT0_IRQHandler(void); void PIOINT1_IRQHandler(void); void PIOINT2_IRQHandler(void); void PIOINT3_IRQHandler(void); static LPC_GPIO_TypeDef (* const LPC_GPIO[4]) = { LPC_GPIO0, LPC_GPIO1, LPC_GPIO2, LPC_GPIO3 }; void GPIO_IRQHandler(void); void GPIOInit( void ); void GPIOSetInterrupt( uint32_t portNum, uint32_t bitPosi, uint32_t sense, uint32_t single, uint32_t event ); void GPIOIntEnable( uint32_t portNum, uint32_t bitPosi ); void GPIOIntDisable( uint32_t portNum, uint32_t bitPos i ); uint32_t GPIOIntStatus( uint32_t portNum, uint32_t bitPosi ); void GPIOIntClear( uint32_t portNum, uint32_t bitPosi ); void GPIOSetValue( uint32_t portNum, uint32_t bitPosi, uint32_t bitVal ); void GPIOSetDir( uint32_t portNum, uint32_t bitPosi, uint32_t dir );
According to these files I wrote this program.
#include <LPC13xx.h> #define fosc 12 #include "delay.h" #include "gpio.h" void PIOINT0_IRQHandler(void) { uint32_t regVal; gpio0_counter++; regVal = GPIOIntStatus( PORT0, 1 ); if ( regVal ) { p0_1_counter++; GPIOIntClear( PORT0, 1 ); } return; } int main(void){ GPIOSetDir( PORT0, 1, 0 ); GPIOSetInterrupt( PORT0, 1, 0, 0, 0 ); GPIOIntEnable( PORT0, 1 ); while(1); }
But it does not work: Rising edge of the pulse reaches the pins. Interrupt flag is activated. But the interrupt subroutine is not implemented.
At least, you also need to do:
NVIC_EnableIRQ(xxx);
xxx might be EINT0_IRQn.
-> Interrupt flag is activated. Which Interrupt Flag?
-> But it still does not work.
How do you know that, it does NOT work?
By a LED? By a Debugger/break-point?
Based on your picture, not only GPIO0RIS is set for P0.1. GPIO0MIS is also set for P0.1. Bits read HIGH in the GPIOMIS register reflect the status of the input lines triggering an interrupt.
Maybe, show me the picture of NVIC.
In NVIC, scroll down to [PIO0 interrupt], click [PIO0 interrupt], check the [Pending]. It will soon become [Active], then see what would happen.
when I checked pending, became active and program continued with interrupt subroutine while there wasn't any rising edge of pulse at pin.
I may be able to get a simplified EV board of LPC1343 in few days, once I get the hardware, I will do some tests to identify if this is a simulator issue.
Looks like when you manually generate a rising edge signal, GPIOs peripheral triggers an interrupt, but core peripheral NVIC does not catch it.
Hello. Your assistance in this time, thank you. Today I practice test, everything is okay. Keil simulator was the problem.
