How to implement code to support an HID device on the Discovery biard
I would like to implement on the STM32F4 Discovery board the support for an USB device that simulates a sound card, using the same HID protocol that Windows uses.
Specifically, I would like to be able to connect that device to the Discovery board, and to read the stereo stream coming from it at a sampling rate of 192 kHz. The M4F has ample processing power for this, as I do that already with an I2S interface. Now I would like to use the USB port for this new device.
Is there anywhere an example on how to simulate the Windows HID protocol on the STM32M4F Discovery board ?
Thanks.
  • ST’s STM32CubeF4 library supports USB host for audio Sink(speaker)/Source(microphone)
    www.st.com/.../PF259243
    Also, it has a USB headphone(speaker) host example for STM324xG_EVAL board.
    \STM32Cube_FW_F4_V1.1.0\Projects\STM324xG_EVAL\Applications\USB_Host\AUDIO_Standalone\
    Starting on this example, you may customize it, so that it fits to your F4 Discovery board and your target audio device.
    - F4 Discovery has just a full-speed port. Your target may require high-speed
    - ST’s library supports just Synchronous. Your target may require other synchronization.
    - You should increase FIFO size for 192kHz sampling (USB_HostInit(), stm32f4xx_ll_usb.c)
    I’m not sure, if you could make above source code modification with such poor USB experience. You have to learn on USB more, before starting this play.
    Tsuneo
