Problem with wear leveling in RL-FlashFS
Hello all,
I am using Rl ARM Library for file system. It's running on a STM32F4 micro, on a Micron NAND flash chip with 16-bit interface. The file system is formatted with FAT16.
I have noticed that in a test where I access (read/write/flush) the same 1MB file repeatedly, the file system keeps erasing the same few flash pages repeatedly. I would expect that with good wear leveling, the file system should spread the write/erase cycles across the flash memory evenly.
This issue actually results in wearing out the chip in a few days of usage.
The system test case is quite involved so I don't yet have an isolated unit test.
Has anyone seen any similar issues?
