Keil application Image (.bin) files
Hi!
I am working on cortex m3 and am using keil Uvision4. My project requirement is that it should produce a bin file for the application which, I was told, could be made independent of Base address with some keil option.
I did check whatever source I got, but couldn't find such concept.
Can anyone clear my doubt about this?
Thanks!!
  • Use FromELF tool:
    ARM FromELF, 4.1 [Build 791] [Evaluation]
    ARM image conversion utility
    fromelf [options] input_file
    Options:
           --help         display this help screen
           --vsn          display version information
           --output file  the output file. (defaults to stdout for -text format)
           --nodebug      do not put debug areas in the output image
           --nolinkview   do not put sections in the output image
    Binary Output Formats:
           --bin          Plain Binary
           --m32          Motorola 32 bit Hex
           --i32          Intel 32 bit Hex
           --vhx          Byte Oriented Hex format
           --base addr    Optionally set base address for m32,i32
    Output Formats Requiring Debug Information
           --fieldoffsets Assembly Language Description of Structures/Classes
           --expandarrays Arrays inside and outside structures are expanded
    Other Output Formats:
           --elf         ELF
           --text        Text Information
                    Flags for Text Information
                    -v          verbose
                    -a          print data addresses (For images built with debug)
                    -c          disassemble code
                    -d          print contents of data section
                    -e          print exception tables
                    -g          print debug tables
                    -r          print relocation information
                    -s          print symbol table
                    -t          print string table
                    -y          print dynamic segment contents
                    -z          print code and data size information
    Software supplied by: ARM Limited
