Hi All, Currently using KEIL 4 for my development. I am using STM32F427, my application is 210KB but the available SRAM is 192KB. I wanted to use 64KB CCM, how to use and define that CCM in KEIL. Kindly guide with examples how to use the CCM in KEIL.
my.st.com/.../Flat.aspx
Thanks for capturing my post, just tried a piece of code as follows and started looking into Memory window to check whether the values are stored
#include "stm32f4xx.h"
char buf[16] __attribute__ ((section(".ccm")));
void main(void) { int i;
for (i=0;i<16;i++) { buf[i] = i; }
But it doesn't show any values in the Memory Window, as you suggested I updated the scatter file. Could you guide on this.
OOPS I made a mistake corrected here, now able to see the values storing in that variable. Is that can I use CCM as RO or RW section?
