Variable values not visible in UVision when hover over
Hi
This is probably a simple thing but all of a sudden I don't see any variable values when I hover over them in UVision4 and also I can only change values in the command prompt when I have stopped the program in debug mode.
If I run some older programs I'm able to see values when hovering over them and also change variables using the command prompt when the program is running.
I have been copy and pasting program folders to keep backing up my work, but I've checked all files have copied over?
Any help appreciated.
