Good Afternoon to all I'm working with LCP1768 and uVsion 5, and i'm having a little problem sending BYTE (unsigned char, 0x00 to 0xFF), every BYTE with coding greater than 0x7F are being treated like char (0x00 to 0x7F), for example 0x80 turn to 0x00, 0xCA turn to 0x4A. Can someone give me light in this situation?
Here is my code...
#include <LPC17xx.h> #include "Serial.h" #define SW_FIFO_SIZE 512 #define RLS_INTERRUPT 0x03 #define RDA_INTERRUPT 0x02 #define CTI_INTERRUPT 0x06 #define THRE_INTERRUPT 0x01 #define LSR_RDR (1<<0) #define LSR_OE (1<<1) #define LSR_PE (1<<2) #define LSR_FE (1<<3) #define LSR_BI (1<<4) #define LSR_THRE (1<<5) #define LSR_TEMT (1<<6) #define LSR_RXFE (1<<7) #define UART_DISABLED 0x00 #define UART_OPERATIONAL 0x01 #define UART_OVERFLOW 0x02 #define UART_PARITY_ERROR 0x03 #define UART_FRAMING_ERROR 0x04 #define UART_BREAK_DETECTED 0x05 #define UART_CHAR_TIMEOUT 0x06 // Variáveis Serial 0 bool LedTx0; bool LedRx0; BYTE UART0_RxBuf[UART0_RX_BUFFER_SIZE]; BYTE UART0_TxBuf[UART0_RX_BUFFER_SIZE]; BYTE UART0_RxTail; BYTE UART0_RxHead; BYTE uart0_tx_sts; BYTE uart0_rx_sts; uint32_t rdaInterrupts = 0; uint32_t ctiInterrupts = 0; static FIFO tx0Fifo; static FIFO rx0Fifo; void Serial0Init( unsigned int baudRate ) { BYTE x; int pclk, fdiv; LedTx0 = false; LedRx0 = false; LPC_SC->PCONP |= (1 << 3); LPC_PINCON->PINSEL0 |= (1 << 4); /* Pin P0.2 used as TXD0 (Com0) */ LPC_PINCON->PINSEL0 |= (1 << 6); /* Pin P0.3 used as RXD0 (Com0) */ LPC_SC->PCLKSEL0 &= ~(3 << 6); // clear bits LPC_SC->PCLKSEL0 |= (1 << 6); // set to "01" (full speed) pclk = SystemCoreClock; LPC_UART0->LCR = 0x03; /* 8 bits, no Parity, 1 Stop bit */ LPC_UART0->LCR |= (1 << 7); LPC_UART0->DLM = 0;//Fdiv / 256; LPC_UART0->DLL = 108;//Fdiv % 256; LPC_UART0->FDR = 0x21;/// LPC_UART0->LCR &= ~(1 << 7); LPC_UART0->FCR |= (0x3 << 6); //(0x3 = 14, 0x00 = 1) LPC_UART0->FCR |= 0x01; LPC_UART0->FCR |= 0x06; NVIC_EnableIRQ(UART0_IRQn); NVIC_SetPriority(UART0_IRQn,30); LPC_UART0->IER = 0x07; //Enable LPC_UART0->LCR = 0x03; FifoInit(&tx0Fifo, SW_FIFO_SIZE, (BYTE*)UART0_TxBuf); FifoInit(&rx0Fifo, SW_FIFO_SIZE, (BYTE*)UART0_RxBuf); } void Serial0Done(void) { FifoClear(&tx0Fifo); FifoClear(&rx0Fifo); } void UART0_IRQHandler(void) __irq { BYTE intId, lsrReg; BYTE byData,bTmpTail; intId = ((LPC_UART0->IIR)>>1)& 0x7; if(intId == RLS_INTERRUPT) { //RLS lsrReg = LPC_UART0->LSR; if (lsrReg & LSR_OE) uart0_rx_sts = UART_OVERFLOW; else if (lsrReg & LSR_PE) uart0_rx_sts = UART_PARITY_ERROR; else if (lsrReg & LSR_FE) uart0_rx_sts = UART_FRAMING_ERROR; else if (lsrReg & LSR_BI) uart0_rx_sts = UART_BREAK_DETECTED; } else if (intId == RDA_INTERRUPT) { while((LPC_UART0->LSR) & 0x1) { byData = (BYTE)(LPC_UART0->RBR); FifoPut(&rx0Fifo,byData); UART0_RxBuf[UART0_RxHead] = byData; UART0_RxHead += 1; if(LedRx0) { LPC_GPIO2->FIOPIN &= ~(1 << 2); LedRx0 = false; } else { LPC_GPIO2->FIOPIN |= (1 << 2); LedRx0 = true; } if (UART0_RxHead == UART0_RX_BUFFER_SIZE) UART0_RxHead = 0; } rdaInterrupts++; } else if (intId == CTI_INTERRUPT) { while((LPC_UART0->LSR) & 0x1) { byData = (BYTE)(LPC_UART0->RBR); FifoPut(&rx0Fifo,byData); UART0_RxBuf[UART0_RxHead] = byData; UART0_RxHead += 1; if(LedRx0) { LPC_GPIO2->FIOPIN &= ~(1 << 2); LedRx0 = false; } else { LPC_GPIO2->FIOPIN |= (1 << 2); LedRx0 = true; } if (UART0_RxHead == UART0_RX_BUFFER_SIZE) UART0_RxHead = 0; } ctiInterrupts++; } } void Serial0Transmit(PBYTE data, WORD length) { while (length != 0) { Serial0Transmit_Byte(*data); data++; length--; } } void Serial0Transmit_Byte(BYTE byData) { thr_empty; LPC_UART0->IER = 0; thr_empty = (LPC_UART0->LSR & LSR_THRE); LPC_UART0->THR = byData; if (LedTx0) { LPC_GPIO2->FIOPIN &= ~(1 << 3); LedTx0 = false; } else { LPC_GPIO2->FIOPIN |= (1 << 3); LedTx0 = true; } }
