Hello everybody,
Sorry for my english.
I start a new prog, and so I am at the beging. This the first time that I include assembler code in a program write in C.
When I build all targets I have 2 warnings :
- Warning L1: Unresolved external symbol Symbol: ?C_START Module: STARTUP.obj (?C_STARTUP)
and
- Warning L2: Reference made to unresolved external Symbol: ?C_START Module: STARTUP.obj (?C_STARTUP) Address: 2687H
I read the help of Keil, but it does not do me much.
Note that I validated "Generate Assembler SRC File" in the option of main.c and in the option of "Source Group 1".
In the "source group 1" I have 2 files "main.c" and "STARTUP.A51"
Please find this two files :
main.c :
#include <REG51.H> void ecriture_flash(); void main() { unsigned char unite; unsigned char dizaine; unsigned char centaine; #pragma asm ORG 0000h JMP 2000h ORG 2000h #pragma endasm SM0=0; //UART en mode 1 SM1=1; //UART en mode 1 SM2=0; //Gestion multiprocesseur inactive REN=1; //Reception active TMOD=0x20; //Config Timer 1 en mode 2 et mode temporisateur TH1=255; //56000 Bauds TR1=1; //Active le timer 1 TI=0; centaine='3'; dizaine='2'; unite='1'; DPH=0xFF; DPL=0xFF; ACC=centaine; ecriture_flash(); DPH=0xFF; DPL=0xFE; ACC=dizaine; ecriture_flash(); DPH=0xFF; DPL=0xFD; ACC=unite; ecriture_flash(); DPH=0xFF; DPL=0xFC; ACC=0xDD; ecriture_flash(); while (1); } void ecriture_flash() { #pragma asm MOV R1, #02h MOV 0B1h, #0 CALL 1FF0h MOV 0B1h, #1 #pragma endasm }
