SPI and SD card
Hi everyone,
I found SD.c that works with SD card thorough SPI for LPC series. But I work with AT91SAM7x256 and I want to change the code to work with this series. I am working on USB and new to memories. This very important to me. I am so grateful for your help.
can anyone help me?
#include"lpc214x.h"
#include "PCF8833.h"
#define SD_Disable() IO0SET |= 1 << 20  //SD Chip Select Pin is P0.7
#define SD_Enable() IO0CLR |= 1 << 20
typedef unsigned char INT8U;
typedef unsigned short INT16U;
typedef unsigned int INT32U;
char CMD[]={0x40, 0x00, 0x00, 0x00, 0x00, 0x95};
INT8U SPI_RW(INT8U data)
        SSPDR = data;
        while((SSPSR & 0x01) == 0);
        return(SSPDR);
void spi_init (void)
   INT32U i;
   /* SSEL is GPIO, output set to high. */
   IODIR0  |= 1<<20;
   IOSET0   = 1<<20;
   /* SCK1, MISO1, MOSI1 are SSP pins. */
   PINSEL1  = (PINSEL1 & ~0x000003FC) | 0x000000A8;
   /* Enable SPI in Master Mode, CPOL=1, CPHA=1 (Clock low-active). */
   SSPCR0 = 0x00C7;
   SSPCR1 = 0x0002;
   SSPCPSR = 0xFE;
   /* Send SPI Command with card not selected at 400 KBit. */
   for (i = 0; i < 16; i++) {
      SPI_RW (0xFF);
   /* Enable SSP auto select. */
  • INT8U Write_Command_SD(INT8U *CMD)
        INT8U i = 0, response = 1, retry = 0;
        SD_Disable();
        SPI_RW(0xff);
        SD_Enable();
        for(i = 0; i < 0x06; i++)
            SPI_RW(*CMD++);
        SPI_RW(0xff);
        do
            response = SPI_RW(0xff);
            retry++;
        while((response== 0xff) && (retry < 100));
        return(response);
  • INT8U SD_write_sector(INT32U Number_Sector, INT8U* Buffer)
        INT8U response,response_1,retry;
        INT16U i;
        //Command 24 is a writing blocks command for SD/SD-Card.
        INT8U CMD[] = {0x58, 0x00, 0x00, 0x00, 0x00, 0xFF};
            INT8U CMD_SET_BLOCKLEN[]={0x50,0x00,0x00,0x02,0x00,0xFF};
            retry = 0;
        do
        {  //Retry 100 times to send command.
            response = Write_Command_SD(CMD_SET_BLOCKLEN);
            if(++retry >= 100)
                    return(1); //block read Error!
        while(response != 0);
            SPI_RW(0XFF);
        Number_Sector  <<= 9; //addr = addr * 512
        CMD[1] = ((Number_Sector & 0xFF000000) >> 24 );
        CMD[2] = ((Number_Sector & 0x00FF0000) >> 16 );
        CMD[3] = ((Number_Sector & 0x0000FF00) >> 8 );
        CMD[4] = ((Number_Sector & 0x000000FF) >> 0) ;
        //Send Command CMD24 to SD/SD-Card (Write 1 Block/512 Bytes)
        retry = 0;
        do
           response = Write_Command_SD(CMD);
           if(++retry >= 100)
               return(1); //send commamd Error!
    //   for(i = 0; i < 20; i++)
           SPI_RW(0xff);
        //Send Start Byte to SD/SD-Card
        SPI_RW(0xfe);
        //Now send real data Bolck (512Bytes) to SD/SD-Card
        for(i = 0; i < 512; i++)
           SPI_RW(* Buffer++); //send 512 bytes to Card
        //CRC-Byte
        SPI_RW(0xFF); //Dummy CRC
        SPI_RW(0xFF); //CRC Code
    //    retry=0;
            do
        response=SPI_RW(0xFF);//Read Response
            while(response==0xff)
        do
                 response_1=SPI_RW(0xFF);
            while(response_1!=0xFF);
        SD_Disable();
            SPI_RW(0xff);
        if ((response&0x1f)!=0x05) return(1);
        return(0);
  • INT8U SD_Read_Block(INT8U *CMD, INT8U *Buffer, INT16U Bytes)
        INT16U i;
        INT8U retry,response;
        INT16U Block_Len=0;
        INT8U CMD_SET_BLOCKLEN[]={0x50,0x00,0x00,0x00,0x00,0xFF};
        if(Bytes != Block_Len)
            CMD_SET_BLOCKLEN[3] = (INT8U)((Bytes & 0x0000FF00) >> 8 );
            CMD_SET_BLOCKLEN[4] = (INT8U)((Bytes & 0x000000FF) >> 0 );
            retry = 0;
            do
                    if(++retry >= 100)
            Block_Len = Bytes;
        //Send reads a block Command CMD to SD/SD-Card
        retry = 0;
        do
            if(++retry >= 100)
        //Read Start Byte form SD/SD-Card (FEh/Start Byte)
    //    while(SPI_RW(0xff) != 0xfe) ;
        retry=0;
        for(i=0;i<1000;i++)
                response=SPI_RW(0xff);
                    retry++;
                    if(response==0xfe)
                    i=1000;
                    if(retry==1000)
                    return(1);
        //Write blocks(normal 512Bytes) to SD/SD-Card
        for(i = 0; i < Bytes; i++)
            *Buffer++ = SPI_RW(0xff);
        //CRC-Byte
        SPI_RW(0xff);//CRC - Byte
        SD_Disable();
        return(0);
  • SD_INIT()
       INT8U retry, response;
       INT16U i;
       for(i=0;i<250;i++)
      __asm
            NOP
      for(i = 0; i < 0x0f; i++)
            SPI_RW(0xff);
      //Send Command CMD0 to SD/SD Card
      retry = 0;
      do
      { //retry 200 times to send CMD0 command
        retry++;
      while((response != 1) && (retry < 200));
       retry=0;
       do
            CMD[0]=0x77;
            CMD[5]=0x55;
            CMD[0]=0X69;
            response=Write_Command_SD(CMD);
                    retry++;
       while((response!=0)&&(retry<200)) ;
    //  return(response);
    void SD_WRITE(INT8U* Buffer,INT32U Number_Sector)
       retry=0;
      do
          response=SD_write_sector(Number_Sector,Buffer);
              retry++;
       while((response!=0x00)&&(retry<20))       ;
    void SD_READ(INT8U *Buffer, INT16U Bytes,INT32U Number_Sector)
       INT8U response,retry;
       INT8U CMD[]={0X51,0X00,0X00,0X00,0X00,0XFF};
       Number_Sector=Number_Sector<<9;
       retry=0;
       do
          response=SD_Read_Block(CMD,Buffer,Bytes);
              retry++;
       while((response!=0)&&(retry<100));
  • No one can help me?
    Or show me good reference?
  • If _you_ want to port code between these two processors, don't _you_ then think that the processor documentation published by the two processor manufacturers would be good references?
    You have posted some random code you have found, but have not indicated that you have done any own work at all. Have you heven tried to look for code or documentation for your processor?
    You say that this is important to you, but you aren't showing us that it is important by showing exactly how hard you are working on solving this problem.
  • You haven't actually said what help, exactly, you require.
    Where are you stuck?
