Keil CAN LIB missed parameter
In keil CAN library in CAN_rx_object function the MASK parameter for ID of rx messages missed!!!
What is the reason?
  • Hi Saman, yesterday I posted a question very similar to your request. With CAN protocols that have, inside the ID, the source code that could change, should be necessary to introduce a filter only so some bits and not verify all the ID bits. Do you find a solution without change the source code of KEIL library?
    Regards.
