We are to use Ethernet interface circuit for one of product from MCB2300 reference schematic. I can't match specs of oscillator CX07050T3 given in MCB2300 reference schematic with requirements of 50MHz oscillator given in DP83848C datasheet. Also for RMII mode, oscillator will have to drive two pins, one is X1-pin of DP83848C and other is E_RX_CLK of LPC2388.
Can anybody comment whether oscillator CX07050T3 used in MCB2300 design is as per specs given in DP83848C datasheet and also oscillator shall perform well over temperature range of -40'C to +60'C?
Thanks in advance.
Regards, Jagdish
