SSP1 communication through DMA
Hey everyone,
I've been trying to get the SSP1 port on the lpc2388 working to no avail. I have the SSP1 port working by itself but I want to be able to use the DMA. I've read over the manual and a few examples, but I still can't seem to get it to work.
The interrupts aren't firing and I don't see anything being transmitted from the SSP1 port. I know there are some messy parts, but I just want to get it working first and I'll put in error handling, etc. later. This is on a system using RTx by the way. Can anyone see any obvious errors that I have missed?
Here's how I'm configuring it:
SSP1 configuration (works when I don't use DMA):
void init_ssp1(void) {
    // Configure SSP1
    SSP1CR1     = 0x00;                     // Disable module
    SSP1CPSR    = 60000000/4/100000;        // Set 100KHz clock rate
    SSP1CR0     = 0xCF;                     // 16 bit transfers, SPI, CPOL=1, CPHA=1
    SSP1IMSC    = 0x0;                      // Disable all interrupts
    SSP1CR1     = 0x2;                      // Enable module
    // Enable SSP1 interrupt
    VICVectAddr11 = (unsigned long)ssp1_irq;
DMA configuration:
static U16      dma_rx_buf[128];
static U16      dma_tx_buf[128];
void init_dma(void) {
    U32 i;
    U16 *rx_address;
    U16 *tx_address;
    // Init buffers
    rx_address = dma_rx_buf;
    tx_address = dma_tx_buf;
    for (i=0; i<128;i++) {
        *tx_address++   = i;
        *rx_address++   = i;
    // Clear DMA interrupts
    GPDMA_INT_TCCLR     = 0x3;          // TC interrupts
    GPDMA_INT_ERR_CLR   = 0x3;          // Err interrupts
    // Configure DMA ch0 for SSP1 send
    GPDMA_CH0_SRC       = (U32)&tx_address;
    GPDMA_CH0_DEST      = SSP1DR;
    // TX burst size of 128 x 16bits, source is incremented after each transfer
    GPDMA_CH0_CTRL      = (0x6<<12) | (0x6<<15) | SHIFT_ONE(18) | SHIFT_ONE(21) | SHIFT_ONE(26) | SHIFT_ONE(31);
    // Configure DMA ch1 for SSP1 receive
    GPDMA_CH1_SRC       = SSP1DR;
    GPDMA_CH1_DEST      = (U32)&rx_address;
    // RX burst size of 128 x 16bits, destination is incremented after each transfer
    GPDMA_CH1_CTRL      = (0x6<<12) | (0x6<<15) | SHIFT_ONE(18) | SHIFT_ONE(21) | SHIFT_ONE(27) | SHIFT_ONE(31);
    VICVectAddr25 = (unsigned long)dma_irq;
When I send I use this code:
void comm_send(U16 *data, U16 length) {
    U32 i = 0;
    for (i=0; i<length; i++) dma_tx_buf[i] = data[i];
    // Enable SSP1 DMA access
    SSP1DMACR = 0x3;
    // Enable DMA ch0 for M2P to SSP1 with peripheral flow control and interrupts enabled
    GPDMA_CH0_CFG = SHIFT_ONE(0) | (0x2<<6) | (0x5<<11) | SHIFT_ONE(14) | SHIFT_ONE(15);
    // Enable DMA ch1 for P2M from SSP1 with peripheral flow control and interrupts enabled
    GPDMA_CH1_CFG = SHIFT_ONE(0) | (0x3<<1) | (0x6<<11) | SHIFT_ONE(14) | SHIFT_ONE(15);
  • This looks wrong for starters
    This needs the be the address, not a pointer to a pointer with the address
    GPDMA_CH0_SRC = (U32)tx_address;
    GPDMA_CH0_SRC = (U32)dma_tx_buf;
    GPDMA_CH0_SRC = (U32)&dma_tx_buf[0];
  • Note also that it matters what memory region your buffers are in. Not all memory ranges are supported by the DMA mechanism.
  • So apparently I made a stupid mistake and forgot to enable the whole DMA.
    I also updated it to force it to use the USBMEM. I've powered on the USB clock in my startup file but is there anything else I need to do to make sure nothing else writes there as well? Should I edit the scatter file to reserve that memory block?
    So with the changes I have some progress. I enable the DMA channels but I get a DMA error interrupt on channel 0 (transmit channel) and the channel is disabled.
    My updated init function looks like this now:
        U32 i;
        // Init buffers
            dma_tx_buf[i]   = i;
            dma_rx_buf[i]   = i;
        // Enable DMA
        GPDMA_CONFIG = 0x1;
        GPDMA_CH0_SRC       = DMA_SRC;
        GPDMA_CH1_DEST      = DMA_DST;
        // burst size of 128 x 16bits, destination is incremented after each transfer
  • I should add that I'm setting the memory address by doing:
    static U16      *dma_rx_buf         = (U16*)DMA_DST;
    static U16      *dma_tx_buf         = (U16*)DMA_SRC;
    Is this the proper way or should I be doing it a different way?
  • Well this was a pretty hard won battle. Finally got it though.
    I had to assign the source and destination addreses like this:
        GPDMA_CH0_SRC       = (unsigned int)&dma_tx_buf[0];
        GPDMA_CH0_DEST      = (unsigned int)&SSP1DR;
  • Still can't get it working when I set the peripheral as the flow controller. I'm getting an error interrupt on both channels although I see some data going through. Is there a specific sequence I need to do to spool the DMA up? Do I need to put a delay between setting up the transfer and receive?
  • So I've narrowed down the problem with my code to memory access. The USB memory location is from 0x7FD00000 to 0x7FD03FFF. If I try to access anything outside of this from the DMA I get a channel error.
    When I kick off the DMA and SSP I configure the following:
    CH0 source is 0x7FD00000 (in USM memory location)
    CH0 destination is the SSP1 data register
    CH1 source is the SSP1 data register
    CH1 destination is 0x7FD02000 (in USM memory location)
    When I set the SSP to be the flow controller it tries to read as much data as possible and errors out when it hits 0x7FD04000. This happens with both the TX and RX SSP transfers. I understand why the error is happening but I don't understand how to configure it so it only fetches what I have set in the bust size and width registers.
    From my understanding I have set them as:
    CH0 Source Burst Size: 128 transfers
    CH0 Destination Burst Size: 128 transfers
    CH0 Source Width: 16bits
    CH0 Destination Width: 16bits
    CH1 Source Burst Size: 128 transfers
    CH1 Destination Burst Size: 128 transfers
    CH1 Source Width: 16bits
    CH1 Destination Width: 16bits
    My goal is to have 128 16bit registers transfered from the SSP and receive 128 16bit registers back. Am I misunderstanding anything here?
