This relates to uVision 4 v4.21.0.0 .
We have a project that requires two targets, "Dev" and "Production" because the dev board is slightly different from the final production board. The plan was to have a top level directory which contains the common code, then a sub direct for Dev and sub directory for Production with the source specfic to those:
Project/ -Dev/ - a.c - b.c -Production/ - a.c - b.c - common_file1.c - common_file2.c
In uVision I have "Dev" and "Production" targets. In Dev target I have "Source" group which contains source from "Project/Dev/" and Production target I have "Source" group which contains source from "Project/Production". And both targets use the common source files in Project/.
However, although the uvproj file contains the correct XML, uVision4 does not treat the source files with in target serparately, I don't quite know what it's doing. If I remove a file from one target, it gets removed in both . Same with editing.
Is there is fix for this? Or an alternative (other than create two separate projects)?
I think there will be issues with object files etc when they have same file name - uv isn't fully supporting paths.
I recommend that you change to:
Project/ -hwrev1/ - hwrev1_a.c - hwrev1_b.c -hwrev2/ - hwrev2_a.c - hwrev2_b.c - common_file1.c - common_file2.c
Now it's possible to build both targets without having multiple c files that would result in colliding object file names.
