Returning multiple values from a function??
I want a function to return multiple values after doing data processing i.e. void test(int a, int b int c) whereas a, b and c have values set and control is returned to the caller with the values sent back.
Try as I may I haven't been able to return values from my function, furthermore I read from someone C doesn't support multiple returns - is this correct??
It seems such a stupid limitation when (supposedly) inferior programming languages like Pascal can support multiple returns in a function / procedure call.
What gives??
Is this just in Keil?? Can I get it to do what I want??
I really want to avoid using global declarations, records or structs if at all possible.
