how to disable "Evaluation version, code size limited to 32K" message
I am using evaluation version of uVISION 5. Every time i start the debugger i get a warning message displaying"Evaluation Version, code size limited to 32K". I am trying to run the debugger from command line for automation purpose, even then i get this message. Can you please let me know how to disable this message so that automation will run without any interrupts? Thanks
  • A good way is to license the product.
    It will stop the warning and might give you a warm feeling inside.
  • Thanks Peter.
    I am running Keil debugger from command line using the below command
    C:\Keil\UV4\UV4 -d path\projectname.uvproj
    I need to run the debugger multiple times for my test case. Every time i run this a new instance of Keil is being opened. Is there any way i can just invoke the project once and run the debugger as many times as i want?
  • "Is there any way i can just invoke the project once and run the debugger as many times as i want?"
    No.
    The debugger is a key part of what you pay the licence fee for.
    If this is a bona-fide evaluation exercise - with a genuine view to purchase - then you should speak to your local Keil sales people.
    But, if you're just after a freebie, you can't really be picky...
