uVision5: "Dynamic syntax check / Code completion module error: deactiv"
when I start uVision5, then I get this error message in the status line: "Dynamic syntax check / Code completion module error: deactiv".
The "deactiv" looks strange - the v somehow cut (althought the status line is much longer - no reason to cut the error message).
The dynamic syntax check / code completion also does not work (on the same PC (WinXP) uVision4.7 works without problems with syntax check / code completion - the syntax check / code completion definitely is switched on in the editor config window - I tried also reboot of PC and start uVision5 directly after boot (without starting uVision4 before) - but I also get this error message).
Anybody has some idea or the same problem?
