Problems getting _at_ to work
I have read through the documentation and searched the knowledge base, yet I cannot figure out why my _at_ statement is not working!! My problem is that I need to locate a block of data at a specific location. I have the tried the following:
BYTE xdata PTMEM[100] _AT_ 0x2000;
unsigned char xdata PTMEM [100] _AT_ 0x2000;
xdata char PTMEM [100] _AT_ 0x2000;
... and other variations with no use. The compiler finds a syntax error C129.
I'm sure it's something simple, but I can't figure it out.
Alternatively, I have removed the _AT_ keyword, and tried using the XD? directive in BL51:
BYTE xdata PTMEM [100]; //in source file
?XD?PTMEM?MYPROG(0x2000)
in the XDATA box under Options.
Any help is appreciated.
Jerrold.
  • Hi Jerrold,
    I have just tried one of your examples and get this, which is what i think you are getting:-
    error C129: missing ';' before '_AT_'
    If i change the '_AT_' to '_at_' ie. lower case, the problem goes away, have you tried that?.
    Mark
  • Hi Mark,
    No, that is one alternative I didn't try! HAHA! I knew it was something easy.
    Thanks a lot.
    BTW, I got it to work by declaring the array in another file.
    //PTMEM.C
    //MYPROG.C
    extern BYTE xdata PTMEM[100];
    //XDATA options
    ?XD?PTMEM(0x2000)
    Now I can get rid of that one-line file.
    Jerrold.
