Hello, Is there a more convenient way to measure the time between 2 breakpoints hits? So far, the only way I know, is to write down the current states or seconds indication, run the software and then subtract the earlier time written down from the current states or seconds indication in the Regs pane of the Project View. Rgds, Geert
The following knowledgebase article explains one method of doing this: http://www.keil.com/support/docs/2026.htm Jon
