Using Bootloader routines from my Flash code
My question revolves using Bootloader routines in my Flash code.
This is legacy code so I have no opportunity to change the Bootloader code.
I have a need to use several Bootloader routines as well as some data in the Bootloader.
I am currently accessing the data by:
	Options for Target 1: L51Locate Code:
			?CO?CRCTABLE(007FH) in the (007FH came from the Bootloader map)
In my Flash code I have a file crctable.c with:
			const unsigned int code crc_table[256] = { .... }
This works great
I would like to access several routines in the Bootloader. These are in a file dspdrv.c in the bootloader, this file can be added to the Flash as well. A short listing of this module (just one routine of many):
void CmdWrite(unsigned char c) {
	DISPLAY_CD = TRUE;
	while((DisplayAddress & 0x03) != 0x03)
	{ PCON |= 0x10; T3 = 0x00; }
	DisplayAddress = c;
	DISPLAY_CD = FALSE;
Note that the routine was not defined as reentrant
Variables that are defined in both Bootloader and Flash seem to make this code compatible:
	unsigned char xdata DisplayAddress _at_ 0x0000;
	sfr P4 = 0xC0;				/* Port 4 - Display control */
  	   sbit DISPLAY_CD = P4 ^ 0;			/*P4.0: Display command/data - data active low */
I modified
				?CO?CRCTABLE(007FH)
to
				?CO?CRCTABLE(007FH),?CO?DSPDRV(120EH) (120EH came from the Bootloader map)
and added dspdrv.c to my Flash code
When I do a build I get:
	**** Warning L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
	SEGMENT:  ?CO?DSPDRV
	**** ERROR L1110: CANNOT FIND SEGMENT
	SEGMENT: ?CO?DSPDRV
My question is how to get this to work.
