L107 Error for functions
Hi!
I have rather a program running on a ADuc 824 (256Bytes DATA RAM?). When I link I get the following errors:
ERROR L107: ADDRESS SPACE OVERFLOW
SPACe: DATA
SEGMENT: ?DT?FNCAPTUREDATA?PTSC_UH
LENGTH: 000005H
SPACe: DATA
SEGMENT: ?DT?FNFLASHREAD?PTSC_UH
LENGTH: 000004H
SPACe: DATA
SEGMENT: ?DT?FNDELAY?PTSC_UH
LENGTH: 000004H
All the segments are Functions.
The memory map gives:
data =151.0 xdata =49152 const=0 code=3403
If I reduce data to 117 by removing some variables I do not get this error.
How do I use these functions AND keep my variables?
All the best
Andrew
  • If they won't fit, they won't fit - so you'll have to get rid of something!
    Or, rather, move it/them somewhere else.
    Are you keeping your variables local, so that they can be overlaid?
    Have you enabled overlaying?
  • Although you have 256 bytes of onboard RAM only 128 bytes minus at least one register bank can be used for variables declared as 'data' (the default for the small memory model). You can declare some variables as 'idata' to use some of the upper 128 byte block but be aware that you will be reducing the space available for the stack.
    You could declare some (more) of your variables in xdata. Also, check the map file to see whether there is a gap anywhere in the data range 0x08 to 0x1f. If so you can force some variables into this range with the _at_ keyword.
  • Hi!
    The local variables only take up 65bytes by themselves (hand counting them). So do functions actually use some of the local memory too?
    How do I enabled overlaying?
    All the best
    Andrew
  • If you are using optimisation level 2 or greater then data overlaying is enabled. I think you should take a look at the .map file to find out exactly what is going where in your data space.
